Sjm9911 wrote:
On my TT lock of the same design, the dead bolt and the latch are 2 diffrent keys. They look simmiler and turn if you mix them up. So if you had the wrong key in the door and turned it you could have jammed it up. I did this to mine when i bought the used TT because i didnt know they were diffrent. So try the other key also.
Well, that would be a totally stupid "feature" to have BOTH locks keyed with different keys..
Although, I believe the OP was able to insert the other key and now the KEY is stuck in the lock also which should not have happened either.
Guess I got lucky, when replacing the locks on our TT it has two doors so we REQUESTED to have both door locks keyed alike so same key opens both locks one both doors..
OP may have to break off the key, then drill out the lock and hope they can jimmy it into the unlocked position..
Not sure if it is a "Trimark" but there was a thread a long time ago which mentions those had a tendency to self destruct in the locked position..
Found a thread on it..
HEREI suspect OP will have to resort to surgical removal of the entire latch/lock assembly which will destroy the entire assy in the process.
