Lostagain__'s avatar
Lostagain__
Nev-R-Lube
I found that Napp has an SKF bearing that they keep in stock. Part number FW115 with steel seal's and there only $43.99. My self, I replaced the axle's with Dexter Ez-lube hub's. After reading up on the nev-r-lube bearing and the failure rate. I want to go on vacation not to find out the axle's are junk. Every dealer I spoke with said pretty much the same thing. There nothing but trouble and if you can, get rid of them. So I did. I ended up working with Tex Trail in Ocala, Fl. on rt-441. They bent over backward's to help. If your in the area, 1-800-259-8712.. Found them on the Dexter web site.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
