otrfun's avatar
otrfun
Explorer II
Sep 13, 2013
OEM Propane Heater vs. Portable 1500w 120 V Ceramic Heater
Most of my traveling will be in warmer, southern climates. However, still want to be prepared for the unexpected. Had a couple of question for those of you who've survived a winter or two on the road:
1. Any particular pros & cons to using a portable 1500 watt, 120 V ceramic heater vs. the typical OEM propane heater (i.e., Suburban)?
2. How effective is a 1500 watt ceramic heater heat in a smaller TT, say 18-20 feet (cab size), when temps get down to 30 degrees or so?
3. Should one do any special exterior "venting" when using an OEM Propane Heater?
4. How long will a 20 or 30 lb. propane tank typically last when heating a 18-20 ft TT in, say, 20-30 degree weather?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,379 PostsLatest Activity: Apr 14, 2026
