jrnymn7's avatar
jrnymn7
Paralleling Power Supply Units Made Easy ???
I am considering paralleling a couple of 20a variable adjustable psu's for 40a charging. According to what I have read on the world wide inter-web, it can be done quite easily, provided the following conditions are met:
... units must be the same brand and same internal parts, (resistors, etc.), be current limiting, and have c.v. as well as c.c settings.
The idea is to parallel them by first connecting the + and - leads from both psu's together, to a single + and - lead, which is, in turn, connected to the load/batts. The belief is the voltage drop over the leads will compensate for any minor fluctuations in voltage output of the two psu's. This will, allegedly eliminate the need for a more sophisticated arrangement, including diodes and such.
In due course, one must also use one of the psu's as the voltage controller, by setting it at say .01v higher than the other unit, and putting it in c.v. mode, while using the second unit as the amperage controller, by cranking it to max (limited) amps, and placing it in c.c. mode. (both units set at max amps)
As I'm sure some of you know, the idea is to cause the two units to properly share the load, by causing the unit in c.v. mode to lower its voltage to match the other's lower voltage setting.
My understanding is the unit in c.v. mode will take over on it's own, once charge current tapers to =/< the max (limited) amp setting of the psu's.
The units I'm considering paralleling are the gophert cps1620.
??? Any thoughts on the feasibility of such a simple set up?
(Thinking back, this seems to be essentially what BFL does with his various chargers.)
Thanks!!
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
