jlscjs
Sep 25, 2013Explorer
TucsonJim wrote:
First thing I'd do: With the trailer hooked up, I'd pull the emergency cable pin out and make sure the brakes are locked up which will take them out of the trouble shooting equation. If not, you might have a brake or wiring problem on the trailer itself.
If you need more instruction on how to do this, let us know.
I tired this but I had no current to the brakes, I have a blue wire and a white wire that are pigtailed into the switch, the white wire reads hot when I'm not connected to the truck and the blue wire reads nothing, even if I pull the pin for the emerg. brake
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
