jlscjs
Sep 25, 2013Explorer
TucsonJim wrote:Terryallan wrote:
IF you pulled the E brake with the controller hooked up. You could have fried the controller. Check the pins on the truck to be sure the controller is still working.
I'm curious what you're basing this on? I've pulled my pin many times with the trailer hooked up and never fried a controller. In fact, I've used it as a secondary emergency brake when parked on a very steep grade many times and never experience a fault with either a Prodigy or a Tekonsha controller.
The same here, I just want to know if anyone has experienced the same issue as I have, not being able to set the controller to 6 volts like the manual says, I hate to spend a 100 bucks on a new controller if it isn't bad, it's just I cannot set it at 6 volts, it shows 12 volts then starts dropping to 0 volts within a few seconds
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
