Vulcaneer
Sep 26, 2013Explorer
jlscjs wrote:
I hate to spend a 100 bucks on a new controller if it isn't bad, it's just I cannot set it at 6 volts, it shows 12 volts then starts dropping to 0 volts within a few seconds
Teconsha has great customer service. Best to give them a call. They can tell you how to best diagnose your issue. I think they will advise you to get out your DMM and check the input voltage to your BC. Should be 12V without the truck running. I think it is the blue wire...but not sure. If that checks good, Then they will tell you what wires to check for the output to the trailer connector. Should be 12V with truck not running AND VOLTAGE TURNED UP TO MAX, AND MANUAL LEVER TURNED ALL THE WAY TO THE STOP. If that checks good, Then check the voltage to the plug pins. If all that is good, then start checking the circuit in the trailer.
Anyway, give them a call.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
