TKW's avatar
TKW
Prodigy P2 Brake Controller Trouble Code
It's snowing today at the wet coast. Chances are the snow and road salt mess up the wiring.
While I was parking my truck (no TT in tow), I noticed the controller display was flashing alternatively P.L. & n.c. I looked it up and it was power interrupted while braking and no connection. And 2 LED lights remains on after ignition turned off which I don't believe it's normal. After a few minutes, I unplugged the controller to avoid further damage.
Anybody has this experience?
  • Boomerweps wrote:
    I get the NC every time I start my vehicle. I think it eventually goes out after a while.
    Yes, that's how mine works too.
    Also, after I turn the truck off the two little dots illuminate for about 10 minutes.
    Both are normal operation.
  • I get the NC every time I start my vehicle. I think it eventually goes out after a while.
  • X3. And if you still can't figure it out, call Tekonsha. The Prodigy has a lifetime warranty. While they may or may not replace it, they will help you troubleshoot the issue.
  • westend wrote:
    The controller is shorting across the umbilical posts due to water inside the connector, most likely. I had my P2 exhibit similar codes when I was disconnected from trailer and a load of icy salt-snow mix around the truck's connector. A full dose of WD 40 cured everything. I followed that up with a spray dose of Caig Deoxit to remove any rust or oxidation.
    X2
  • The controller is shorting across the umbilical posts due to water inside the connector, most likely. I had my P2 exhibit similar codes when I was disconnected from trailer and a load of icy salt-snow mix around the truck's connector. A full dose of WD 40 cured everything. I followed that up with a spray dose of Caig Deoxit to remove any rust or oxidation.
  • Thank you newman fulltimer! I will check on the battery tomorrow. I believe it has been disconnected by my mechanic for some time earlier today to replace the power steering pump. Not sure why. I just guessed this from the missing time from the clock.
  • A few causes 1 if you jumped anything or your batt is going bad 2 plug it into a trailer if it does not change then use a tester if it still has no change then the unit got damaged or the charge or output wire to the trailer is bad
