Rbertalotto's avatar
Rbertalotto
Reading AMPS from a solar panel
I have a 12v - 120W solar panel on my TC. This is controlled by a Morningstar Sunsaver 20 into a single group 27 wet cell battery.
I have a Trimetric 2025RV battery monitor installed.
As far as I can see, the Trimetric does not show the solar panel voltage or amps, it only shows battery readings.
I bought a simple Volt / Amp panel mount meter with a shunt.
DROK 0-100V/50A Digital DC Panel Volt Amps Tester Meter VA 2in1 Red LED Display+Shunt
It included three different wiring scenarios:
The question is...Is there any way to use this meter to report Volts and Amp coming frm the solar panel?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
