- Dutch_12078Explorer III
Fulltimer50 wrote:
Well lets see. He is asking about tanks, as in more than one. MHs have one.
His profile shows that he lives in Ft Worth, TX. You do the math.
Since you're assuming he is still in TX, and he is going to use a TX refiller, do we then assume that every TX refiller follows the TX LP dispensing regulations to the letter? I'm done with it... - Fulltimer50ExplorerWell lets see. He is asking about tanks, as in more than one. MHs have one.
His profile shows that he lives in Ft Worth, TX. You do the math. - Dutch_12078Explorer III
Fulltimer50 wrote:
Dutch_12078 wrote:
aggiebob wrote:
Fickit= repair or fix it. These are removable r
Tanks 1 year old that are empty and need to be re-filled prior to my upcoming trip. I am trying to obtain if I have to remove them from my RV to get them re-filled or can I leave them affixed to said RV.. I thought this to be a pretty simple question, but, apparently, I don't know the correct phraseology needed to get the information I need.
There's basically no good answer to your question available here, since different refillers have different policies on the issue, and individual state and local laws may also differ. NFPA-58, the Liquefied Petroleum Gas Code adopted by most states as the basis for their own codes, does not appear to specify either way except in the case of those horizontal DOT cylinders that require filling in a vertical position, which usually requires dismounting them. The best answer for you would likely be to check with the LP dispensing station you intend to use and see what they require.
In Texas there is only one answer. They have to be removed to be refilled.
Since we don't know where the OP is planning to have the cylinders refiled, my answer stands. - ughExplorer
Not if the tank is bolted in MH. - Fulltimer50Explorer
In Texas there is only one answer. They have to be removed to be refilled. - red31ExplorerRemove your removable cylinders and take them to a propane supplier.
If you were on the East side of the metroplex I'd suggest Tractor Supply @ 1.89/gal (mesquite). They might remove the cylinders for you but I never expect the propane filler to remove empty or full cylinders for me. - Dutch_12078Explorer III
There's basically no good answer to your question available here, since different refillers have different policies on the issue, and individual state and local laws may also differ. NFPA-58, the Liquefied Petroleum Gas Code adopted by most states as the basis for their own codes, does not appear to specify either way except in the case of those horizontal DOT cylinders that require filling in a vertical position, which usually requires dismounting them. The best answer for you would likely be to check with the LP dispensing station you intend to use and see what they require. - RJsfishinExplorerQuote:
It is NOT illegal in most areas to Text and drive. But it IS dangerous for them and YOU. Doug
Well, you right about something - Easiest way is to remove them, take them to local propane dealer and have them filled.
- aggiebobExplorerFickit= repair or fix it. These are removable r
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
