saraajmele's avatar
saraajmele
Repeat Cummins 5.9 electric lift pump failures
Hi our shops team has been tasked with troubleshooting a unit with repeat lift pumps failures. It’s on its fourth lift pump and all have have failed in less than a hour of run time. The chassis is a 1999 Holiday Rambler Endeavor. While doing research on the issue we found a 8/13/15 post by retiredtravelers2013 with possibly the same issue. The post was never updated with a fix. Does any one here know the out come of the post or has a issue such as this? We would use the information to troubleshoot the issue and post updates as we work through the issue. The unit is equipped with a VP44 and a electric 12 volt lift pump. Thanks
