I had to peel back a corner of my rubber roof to repair the wood underneath. I will need to glue the rubber back down. Is there a specific type of glue that I need to use?
I just had this very same conversation with the folks at Alpha roofing... They suggest using - 3M 77 spray adhesive
They have done a ton of studies and found this to be the best... spray the roof area to be replaced, reconnected , spray the membrane while BOTH are tacky press together and use roller to adhere the 2 together...
Hi—you can use a non-solvent based contact cement. Make sure both surfaces are dry and coat with the non-solvent contact cement. You have to be careful laying the rubber back down as once it makes contact, it cannot be moved. Sort of like applying contact paper.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
