401nailhead's avatar
401nailhead
seeking advice: 4+ accessory repairs on a 19 year old RV
ok, this is a lot for me to ask, but I know some folks will be there for me, as time permits. We bought the 1996 Coachmen RV van two weeks ago in a somewhat competitive as-is/great price rush, so I knew we would have a few repairs and upgrades to consider.
The 19 year old Coachmen Chevy van is new to us. I have at least some repair sense, having old cars for many years, but RVs and their accessories and appliances are new to us.
Here are the things I am working on; any advice will be appreciated; thanks in advance:
-older vent fan on roof, doesn't work, doesn't look that great, probably needs re-sealed; I just went ahead and purchased the standard fantastic-fan, I'll figure out the installation from online info and videos. Curious if this has its own 12v fuse?
-carbon monoxide and propane sensors (long, narrow individual styles mounted over and under each other) - look original - were disconnected. I connected them today, both go on, one tests well, other questionable on test (no alarm). Online info says replace after 5 years. These are likely as old as the van. They are expensive I see, but life is precious. Any confirmation that it is time to replace? run, don't walk to buy replacements?
-trying to figure why the gas water heater seems to heat whenever the coach power is on, whether or not the heater switch is on - could this be a broken switch, always on (even though it is a gas heater)? Does it decide on its own to ignite? Today I was not sure it turned itself on, but previous says I think it did.
-3 way refrigerator trips the breaker within about 60 seconds or less every time on 120 power when plugged in, but works fine long term on 12V when plugged in or van running. Have not tested on gas yet, but 120 power trips the breaker again and again
-microwave runs 3 to 5 seconds then stops. On low power it ran 8 seconds maybe. It is not tripping a breaker, just stops running (and clock starts flashing as if power went out). I thought it was tripping breaker at first, but now realize it is just stopping, and I just need to re-set clock. I assume I need a microwave repair, or replacement, but want to figure out which. Nothing suspected in coach, or breaker box (I don't think?).
-last item is just general water-proofing, leak sealing. I figure, just look for moisture or wetness after rain, remove old sealant as needed, use new sealant as needed.
thanks again for any advice, sorry to have the long list, but figured I would throw it all on the table.
God Bless America, the open road, and the freedom of RV's!
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
