gmg's avatar
gmg
Slide out failure
We have a two slide system that is hydraulic operated with a single electric motor driven pump. Upon bringing in the slides the first one moves fine and then the second larger one starts moving normally about half way then the motor stops. After a few seconds I tried again and it moved a little more then stopped again. Tried it again and it completed the trip. When running, the motor and pump seem to be running normal speed and not dragging. It just stops prematurely without me releasing the rocker switch. Any ideas what is going on here?
