Rbertalotto's avatar
Rbertalotto
Solar Panel Problem?
Last year I installed a 120w solar panel and a SunSaver 20L controller to my Truck Camper.
To monitor the system I installed a TRIMETRIC TM2025-RV / TM2025-A BATTERY MONITOR.
And to read the voltage and current directly from the solar panel I installed a simple panel mount meter and shunt.
Here is the SunSaver install:
And here is the Trimetric and the small V/A Meter:
The Solar Panel's neg lead goes through the panel meter shunt before it is connected to the SunSaver
The SunSavers neg output is run through the Trimetric's shunt before it is connected to the battery.
My problem is I'm not seeing any current from the solar panel. Even if I bypass the panel meters shunt I still see no current on the Trimetric.
When I substitute my battery charger for the solar panel, the trimetric reads positive amps flowing into the battery. With just the solar panel on a bright sunny day I'm seeing 21-24 volts, but no amps.
I'm starting to think the solar panel is defective.
Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
