greg121
Nov 09, 2017Explorer
Water Heater on Electric Problem
My 17 year old Suburban water heater quit heating on electric. No voltage at the element or either thermostat/hi limit terminal (and yes it was the AC not 12vdc thermostat). The tank switch has been frozen in the on position for several years and taking things apart to check voltage at the tank switch would be a real major pain anyway. The breaker on the house panel is closed (and in fact all are in the event its not wired to where it says it is) with voltage at the breaker.
What do I run my multimeter lead to checking for power at the inside wall switch (checked ok for continuity)? Is it the neutral or hot that is switched? Suburban manual schematic looks like its the hot, So, a handy house neutral (larger slot?) or ground? At the tank I just go to the metal frame.
