ggadwa's avatar
ggadwa
Water Pump issues or is it a CHECK VALVE ISSUE???
Just did a three week trip with our Eagle Cap Camper. Late in the trip we noticed when we ran the water pump and ran water no matter whether it was a short quick run of water or enough water to make the pump run again. Then turned if we turned the water off and back on there was NO water pressure what so ever No water comes out of the tap until the pump is turned on. In other words the water line is not holding pressure for even a couple minutes.
Is the PUMP Failing or is there a Check Valve that I am not aware of that is Failing?????
Appreciate any wisdom out there!?!!?!??!
GARY
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
