rerod's avatar
rerod
Will a honda eu2000i power a 9 Amp Wayne PLS100 water pump?
Hello people.
I pump treated colorado stream water to a shower holding tank when boon docking and had lift problems with the little giant 110v 1/10 HP pump I have and would like to replace it.
Would my eu2000i power the Wayne PLS100 Utility/Sprinkler pump? It says it draws 8.5 amps, but I cant find startup amps.
Thanks!
https://www.northerntool.com/shop/tools/product_200311411_200311411
A couple of comments on amazon sounds like its marginal..
"I supply this pump with a 1500 Watt continuous 12VDC inverter, which can supply 3000W peak. The pump uses about 975 Watts while running steady but exceeds the 3000W peak power of the inverter when starting with a 50 ft long 3/4" garden hose full of water attached. When the hose is empty or detached, the pump can start. If I had it to do over, I would supply the pump with a 3000W continuous inverter. see less"
And..
"This little pump has worked well for me. I have put about 50 hours use in it and it has only shut down once due to overheat using over 100 feet of extension cord. It will run two impulse (50ft. radius) sprinklers from my 2000 watt Honda generator. Three sprinklers only shoot about 40-45 ft. Switch is handy. I might should even give it five stars, but the handle (also handy) bolts vibrated out.
And
"I rewind motors for a living and I always get guys trying to start motors with generators. What they don't seem to get is the start up amperage of a motor is way more than the run amperage. This usually leads to under voltage during start up and either kicking off the overload, popping the start capacitor or toasting the start winding. Trying to start 1hp motor of any brand on a 12 amp generator is just stupid. The motor will need about 20 for start up alone without any load on it. "
  • Maybe swap the motor's factory capacitors for a soft-start like the Micro Air?
  • time2roll wrote:
    I ran a 1/3 HP sump pump with a Honda 2000 when I had it. (might be 1/2 hp but the label is off)
    The 1000 I had would not run it.
    1/10 hp should be easy. 1 hp probably not due to start up surge.
    What is the lift, pressure and volume you need?
    The last camp site I had, we had maybe a 10' lift.. I looked at other secluded camp sites that had about 50' down to the creek and know my little giant 1/10 HP pump would never do that.
    The water doesn't pressurize anything and simply dumps into a 125 gallon holding gallon tank. I'm not to worried about how long it takes. Just if it will do it in under a hour.
    Chris Bryant wrote:
    Not answering your question, but I have a real nice little Honda water pump that pumps great. Tiny little thing, 1/4 the size of the eu2000. Not sure if cost though
    I'm also considering the Honda WX10.. But Iv got to many gas engines I barely use as it is! I could also use the Wayne PLS100 electric pump at my farm to irrigate my garden, so it would have more than one use unlike the honda gas water pump. I also read in the reviews for the Wayne PLS100 that one owner compared it to a honda WX10 he had and the Wayne out performed it..
    But it would really stink if I bought the Wayne, and my 2000i wouldnt power it..
  • Keep in mind the op is in the Colorado mountains, so altitude is a huge factor.
  • Starting watts are 3 times running watts (probably a capicitor start motor. I think your 200 will start it (no load) maybe.
  • Not answering your question, but I have a real nice little Honda water pump that pumps great. Tiny little thing, 1/4 the size of the eu2000. Not sure if cost though
  • I ran a 1/3 HP sump pump with a Honda 2000 when I had it. (might be 1/2 hp but the label is off)
  • 8.5 is max amperage draw. Converts to 1020 watts. In run mod it is 745 watts.
    EU200I should run it without any problems. Issue would be other connected load to genset while operating the pump.
  • The answer is "maybe". I know one Honda 2000 will not run my air compressor requiring 1300 watts. Electric motors on items like compressors and water pumps take a lot of surge wattage to get the motors started. Honda invertor style generators don't handle surge wattage well at all, though they can handle the operating wattage.
    In talking to Honda and the compressor mfg, they doubted even two Honda 2000s could start my compressor.
    Having said that, I think one Honda 2000 will handle the surge starting wattage of your 900W pump, but you won't know until you try.
    Bill
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
