Gray_Fox
Mar 20, 2015Explorer
2013 Ford Diesel
Is the 2013 Ford Diesel a good engine, I need it to pull my 36' 5th /w. Looking to move up. How about the 2015 are they any better. Thanks for any help.
Turtle n Peeps wrote:And the vast majority who have them have nothing but praise for the 6.7.
Going with this logic I'm sure the vast majority had no problems with their 5.7 Olds diesels. Must be a great engine if a majority has no problems with it. :S
The Mad Norsky wrote:BB_TX wrote:
Most of those links come from two sites, one ford forum and the videos from the same guy. If you go to any forum dedicated to a single subject, whether vehicle or anything else, you will naturally find posts about problems experienced and someone seeking help or sympathy. Same if you go to a specific RV brand web site. So don't put too much into those as there has been no widespread postings about problems with the new Ford diesel.
Except for a few who post here, there is rarely anything posted here about a problem with the new Ford engines. And the vast majority who have them have nothing but praise for the 6.7.
And therein IS the problem. The very few members who post here on this forum.
And of these very few, there are two who have had their HPFP's self destruct. One we all know about, Ricatic.
Second was much quieter about his troubles. Luckily he had just had the fuel filters changed at Ford dealership, because Ford tried to hose him on warranty as they did Ricatic. But, after seeing the service records for his truck, Ford did warranty the fuel pump failure.
So take our small sampling for what its worth. But having two failures in such a small sampling size is mind boggling, especially considering not all of these forum members even drive a Ford.
And to the OP here. Again I say go for the 2015 and newer Ford. The pump on the previous years is just such a hit and miss. Great for those that have not yet had problems. Terrible for those few that do.
And know that when the pump goes bad, there is no warning, no symptoms. The CEL (check engine light) comes on your dash and your vehicle quits running.
Let us just hope that at that moment you were not trying to merge onto an interstate with an 80,000 pound 18 wheeler charging towards your tailgate.
Turtle n Peeps wrote:resident Ford basher here.
I hate to break up the Kumbaya love feast for the 6.7.........but I will for the sake of the truth. :B
The 6.7 had some common problems. Here is the short list:
Turbo problems.
Turbo problems.
More turbo problems
Valve problems
Valve problems
Valve problems
More Valve problems
Bearing problems
6.7 breakdown and inspection.
Some will rally about HPFP failure. Although there have been quite a few HPFP the truth of the matter is there have been way, way, way more turbo failures so I won't bother giving you links for the HPFP failures. They are out there and so expensive it will take your breath away.
The problem with talking to people that own these engines are that if they don't suffer from any engine problems they think they are a great engine. This is just not the truth and false reasoning at its worst.
Case in point is I own several 5.7 diesels and up to last year drove one to work on a daily basis. Never had anything go wrong with the engines even though I know this engine is the worst diesel engine known to man kind. If I didn't know anything about diesel engines (like most don't) I would go around and recommend this engine to everybody because it has been so good to "me".
That is the bad news. The good news is Ford has fixed the valve problems, updated the turbo, and has refined a lot of stuff on this engine for 2015. In short, it's a good designed engine with some problems and Ford has addressed those problems in 2015 going forward.
Is it worth it to buy a used truck with a 6.7 diesel in it? Only you can answer that. :)
