harmanrk wrote:
Groover wrote:
harmank,
What is your curb weight and what is your milage empty? When the 6.7 was still offered in the F150 the EPA ratings indicated that it burned a lot more fuel than the 3.5Ecoboost. That and weight is what kept me in the F150, not cost. The cost difference was minor as you observe. Also, the last time I checked you can get a lot of the features that are not available on a F150 max paylod on the F250.
Curb wait should be 7645 (10000-2355) before the bed liner and tonneau went on (another 100 for the two).
Only about 400 on it so far, so mileage is questionable, but out on the highway I had the meter showing 18.5 and climbing on a 200 mile round trip (72-73 MPH) That's as good or better than the Expedition it replaced
On the legal paper, I'm limited to 10000, but the combined axle weights add up to 11540. Which gives me a fair bit play on where the weight gets placed.
The bed height is noticable. I am left thinking that over 60 months that tailgate step (400 dollar option) would have been under 7 dollars a month .
If you can get 18.5mpg out of the 6.2 that is very impressive, especially on an F250. It was only rated for 16mpg highway when it was offered in the F150 and that was a lot lighter truck. http://www.fueleconomy.gov/feg/PowerSearch.do?action=noform&path=1&year1=2014&year2=2014&make=Ford&model=F150%20Pickup%204WD&srchtyp=ymm
And yes, you should have gotten the tailgate step and the factory bed liner.
For reference my 2016 F150 Lariet crewcab with 6.5' bed and very loaded weighs 5,600lbs with bedliner, bed steps, sunroof and FX4 package. So nearly 2,000lbs lighter with more equipment. The only thing that it does not have is power steps.
You probably do have a quite a bit of wiggle room on the weight capacity. I used to run my 1991 F250 regularly with the rear axle loaded to tire capacity(about 3,500lbs). I never broke anything but I did get in the habit of downshifting every time I applied the brakes.
