Charlie_D_
Mar 14, 2020Explorer
ShinerBock wrote:I am sure the rocket has a catalytic converter and particulate filter ;)
I also think it is a bit ironic that the government is cracking down on diesel brothers yet Elon Musk can blast all those Kerosene(#1 diesel fuel) rockets in the air each one worth the emissions of hundreds of thousands of these trucks. I guess if you have enough money and lobby the right people, then you have free reign to make your own rules and do as you please.
Cummins12V98 wrote:SidecarFlip wrote:
I think if the GUVMENT requirez uz to have all this equipment on our trucks they should maintainz it.
You comment is not really worth a reply except to say it smacks of ignorance on your part.
Thanks, nice you feel the need to call names.
BTW you should put " around what "I" said.
SidecarFlip wrote:
Maybe wrong, maybe right. 2012 is Tier 4 which essentially means no visible particulates emitted from the tail pipe. Once you did the 'delete' you violated the Federal Clean Air Standard for your vehicle so you assume all liability and conversely, the resale value has dropped as well. You may pass it off to another owner but if it don't pass emissions testing down the road, or the next owner is subject to the opacity test and fails, the liability comes right back on you as the 'deleter'. How it works, like it or not.
My 2007 7.3 is a Tier 2 engine. I blows minimal particulates but because it's a Tier 2 emissions engine, that is acceptable. Yours however is not.
Getting tired of isn't getting it repaired correctly. You took the easy way out, nothing more.
SidecarFlip wrote:
Like the lights, all about accountability and common sense. If I was LE, I'd be wailing through ticket books nailing inconsiderate people with illegal 'off road use' only light bars running them on public streets and highways.
Far as exhaust opacity concerning diesel engines is concerned, the Federal Department of Transportation already has guidelines and regulations in place as well as testing equipment for big trucks that can be used for pickup trucks as well.
Really simple equipment that measure ambient light transmission through the exhaust stream of an engine. The test sequences is as follows... The sensing modules are set up parallel to the exhaust and the operator is instructed to throttle up the engine to maximum governed speed (floor the fuel pedal) and the exhaust stream is measured for visible particulates (smoke) and those tests are compared to the Tier requirement for that particular build year (because not every diesel engine on the road today is a Tier 4 final engine). If the measured visible particulate output is above the requirement for that build year, the operator / owner has to bring the vehicle into compliance and at the official's decision if the vehicle has to be repaired on the spot or if the owner or operator can drive away and get it repaired at another location.
Besides getting cited for non compliance, you get a hefty fine.
How it works and the test can be administered anywhere, weigh station, rest stop or in a truck stop for that matter... anywhere. The equipment is completely portable and does not require specialized training, IOW, anyone can administer the test.
I'm not a tree hugger but stupid is still stupid.
