dodge guy wrote:
Correct! I have a V-10, used to have a Dodge conv van but traded it in on the X. I am a certified diesel tech. and yes by the time you pull up to a fuel pump the truck is safe to shut down, unless your spooling up the turbo waiting in line!
Many people are not aware of how a diesel operates, so I can understand some of the misinformation I read here. this is usually why they post their "reasons" for allowing it to idle. the fact is it is not necessary, unless the gas station is at the top of a mountain on the side of the hwy with no vehicles in line and you pull right up, then yes, you need to let it idle for a few minutes.
I rarely wait in line, so that's not an issue.... Spooling a turbo isn't what creates the shutdown requirement, it's heat. A turbo will slow down by the time you pull up, which is the only thing your spooling comment refers to, but that doesn't mean it's cool.
If the exhaust is still 400-600° coming out of the turbo then it's too hot, and surely you should understand that. It takes a lot longer when towing for a turbo/exhaust to cool down than pulling over and stopping at the pump.
Engine oil wile coke if it sits in those temperatures, and without air or oil flow it wont take too long to heat up a bearing inside a turbo.
Most people don't watch EGT's after shutdown, and have no clue how much, and fast, they rise when a proper cool-down wasn't applied.
transamz9 wrote:
Most truck stops I stop at while traveling are right off the interstate and 90% of the time I can drive right up to a pump. I also run a pretty hot tune on a stock turbo so there are times I feel I need to let'er idle while pumping. You would be surprised at the people that tows with hot tunes so your assessment that it don't hurt to shut them down don't apply to all diesel trucks on the road.
Tuning not need apply :-)
My truck ran higher EGT's and took longer to cool-down with the stock tuning than it does now at over 130rwhp more than stock. Emissions have really driven the EGT's up, which has increased cool-down time.
Some turbo's are water cooled, but even then they still need a cool down.
