TN_Sportsman
10 years agoExplorer
Newbie trying to match a TC to my 1500 HD
Well I'm a newbie here looking to purchase my first TC. I have been doing a lot of research, but finding many conflicting answers/opinions regarding matching campers to trucks. First, here are the specs for my truck:
2003 Chevy 1500 HD 4x4 Crew Cab, 6.5' bed, 6.0, 4L80 transmission, 3.73 gears,4 wheel disc brakes, E-rated tires, Quadrasteer, 8600 lb. GVWR, 4410 lb. Front axle, and 6000 lb. rear axle. From my understanding, the "1500" badge is misleading to most, as it actually specs out nearly the same as a 2500 non-HD.
IF my truck is capable I would like to find a hard side camper with all the amenities including a wet bath. I am looking at used (under 8K). I like the thought of the Lance Lite 815 (2003 model 1695 lbs.). I also found a nearly new 2005 Mountain Star by Travel Lite model 890R (1760 lbs.). There will only be 2 of us at most camping, but I will be towing a bass boat (maybe 250 lbs. tongue weight?). The sticker in my glove box says my "cargo rating" for a truck camper is 1731 lbs. This seems light unless GM is allowing for a huge "fudge factor". I haven't weighed my truck yet, but Google says I am about 5800 lbs. If I have a GVWR of 8600, shouldn't my "payload capacity" be 2800 lbs.? Of course, I know that you have to factor in all passengers, gear, tongue weight of boat, etc. (1000 lbs.?).
Any thoughts on what campers would be a good safe match for what I am trying to do? Also, what sort of equipment am I going to need in terms of tie downs, suspension help, etc. Any info and insight would be appreciated. Thanks!
