DirtyOil
Aug 29, 2015Explorer
OMG!...
http://www.msn.com/en-ca/autos/news/10-carmakers-sued-over-keyless-ignitions/ar-BBm9LFr?li=AA8hc8
The gene pool needs more chlorine...
Perrysburg Dodgeboy wrote:
Also in my Ram if you leave the truck with it running there is an warning that says over and over THE KEY FOB HAS LEFT THE VEHICLE along with a warning on the dash and a chime sounds. If the fob does not return in ten minutes the truck shuts down.
2003silverado wrote:
At least with keyed ignition vehicles most people need the same key ring to get back in their house when they return home. I don't understand why the vehicles don't shut off when the fob gets over 10 feet from the vehicle. If you need to leave it running then you leave the fob in the vehicle just like you would leave the keys in the ignition on other vehicles.
carringb wrote:
Its easy to dismiss the claims, however when you consider that most new cars are so quiet many older individuals cannot hear them, combined with a non-intuitive operating parameter that allow the engine to run when you take the "key" (or in this case a fob) out of the vehicle, it puts people at risk.
Would you want to lose your parent or grandparent because they are caught up on technology? From a Human Factors standpoint, the current systems in many cars most definitely increase the probability of somebody making a potentially fatal error.
