Mammoth501
Dec 25, 2021Explorer
Durb wrote:
This is a real long shot. Try hitting the retract button and see what happens. Possibly it could have been wired wrong. Or, someone held the extend button and the awning rolled up backwards causing you to bump up on the stops and shutting itself down.
Try bumping the switch back and forth while observing the motorized end. Zero movement means no juice. Odd that Northern Lite didn't detect a problem on the PDI. Good luck.
I tried hitting the retract button and there's no movement or sound what so ever. My guess is there's no power going to it. I took the switch out of the wall, thought maybe a loose wire but they're all attached. I don't know the wiring on this rig at all so I don't know if the switch is wired correctly. I brought some tools with me just not a voltage meter so I'll have to go get one and see if there's even power going to the switch. Start there I guess. The other thing is, shouldn't there be a fuse for the awning somewhere? The fuse panel says nothing about an awning and I don't see any fuses anywhere else on the rig.
When I picked up the camper it was covered in snow and ice so they told me not to play with the awnings, witch I understand but I wonder if they knew about this problem and didn't want me to find out on pick up day. Either way, they are the ones that should fix this but I'm hoping that it's just something simple since everything is brand new so I don't have to waste time going back to the dealership.
I should also add that I do have power going to the LED lights on the awning, they work just fine. Don't know if that says anything or not
44,068 PostsLatest Activity: Jun 21, 2026
