sky_free
Sep 11, 2014Explorer
The 15A switch wire is violet with a green stripe. This post helped me find where they are from the Ford Enthusiast site. This one I just found is better. I think you have a 2013 and mine is a 2012 but they should be the same.
If you are mounting the camera lower there is no reason to run the wires through the TC at all. I just ran everything under the truck, wrapped in split loom and zip tied up to the frame. I built a 3' or so extension cord out of 2 flat-4 male/female (2 male/2 female) trailer wire plugs purchased at Walmart. These are fairly waterproof and allow me to shorten the wiring harness when the TC is off so it doesn't hang down.
44,070 PostsLatest Activity: Sep 18, 2026
