sky_free
Dec 05, 2014Explorer
Powelligator wrote:
Sky Free,
Thanks for responding. In my truck I have the factory touch screen thing in the dash - MyFord Touch I think. So everything is OEM.
The way you wired up your upfitter switch as I understand it is when the switch is on you send power to the reverse light circuit in order to send the backup signal to the head unit? Does this in effect trigger your backup lights?
Thanks,
Joe
You are correct, but it does not trigger the backup lights because I used a diode that only allows power to go FROM the light to the head unit. The diode is placed close to the tap-in point before it T's into the other wire of course.
44,070 PostsLatest Activity: Sep 18, 2026
