Snowman9000's avatar
Snowman9000
My 100w portable solar setup
I built a 2x50 watt folding pair of panels. Many photos below.
These panels from ML Solar
I took the advice of Don the Pianotuna and used loose-pin hinges. I had to put each half in the vise and tap the loops with a block of wood to bend them off center, so they would stay out of the way between the two panels. Astute observers might notice the extra holes drilled in the frames, because first I tried the hinges as they came, and the panels would not sit straight.
The loose pin hinges allow me to stow the panels separately, which helps in my particular storage situation for a goofy reason not worth mentioning.
I used 50' of 12-2 low voltage landscape cable. It is sun-resistant. I cut it in half, and the 25' will get me to a spot on any side of the camper. The next 25' might be needed to find sun. I might invest in another 50' roll too. The voltage drop is 3% per 25 feet.
I used Anderson Power Pole connectors, on the panels and the wiring. For legs, I drilled 7/8" holes in the panel frames, and attach 1/2" conduit connectors in the holes, holding the legs. Simple to unscrew and remove. If the holes get wallowed out, I'll rivet a piece of sheet steel on for a tougher mount. The legs in the photo don't show it, but they will have feet with holes for tent pegs. Just flatten the end of the conduit and bend the flat piece so it lies flat on the ground. I also have a longer set of legs to tilt the panels at about 45º. I will be adding an eye bolt on each lower side of the panel set, also for tent stakes. It will also be a place to attach bungee cords over to the long legs, because the longer legs amplify the slack in my attachment method.
So far I've seen peak amps of just over 6. That's maxed out, though.
OK, time for photos:
I did some work at the camper end of things too. Battery access is through a bread-loaf sized door. The battery sits in a cradle underneath the RV, alongside the van frame. I added a second cradle and battery under there. Both batteries have to be installed and removed from below the van (same as stock).
I used a PVC conduit LB elbow to house a switch for the B.I.R.D (later), a voltmeter with a switch, and Anderson power pole connectors on top going To and From a Morningstar 20 amp PWM controller. Then there is a cable pair with the PP connectors going to the battery (fused). I can plug the solar panel wire into the To port, and the battery cable into the From port. I bought a Turnigy Watt Meter, and installed PP connectors on it. So I can insert it between the battery and From ports, and measure my solar. Also, obviously I can bypass the controller if I want to for some reason. Yes, it's a lot of connections, but a big part of this for me is the learning and the hobby aspect. So this setup lets me measure and also try different things pretty easily.
I've made up PP ends for the HF charger, made a 2 in 1 pigtail so I could run the HF along with the solar, and next I'm going to do something with my B&D 40a charger. I have to use bigger ends for its cables, but I've already made a big (75a) PP to small PP 8 gauge short pigtail to allow me to hook it to the camper. (The small PP's are rated to 45 amps, and Anderson says they are good for more.)
Installing the stuff by the battery was like building a ship in a bottle, even with the battery removed. Seriously, it looks simple but it was a lot of work to install the mounting pieces, the shield and mount for the controller, etc. Working on my back, I felt like I owned a Corvair again. :) OK, photos:
Oh, yeah, the BIRD. The Intellitec BIRD is a bi-directional relay system that provides charging for either the house or chassis battery if it senses charging on the other battery, provided some conditions are met. It's fine and dandy, but if I want to charge ONLY the house batteries, I can't. Not without bypassing the BIRD. Which is what that switch does.
  • Snowman
    Welcome to the Portable Solar Club! I have 185 watts on a portable stand and I never run my generator. LED lights make it even better!
    Good luck
    Bill
  • How much solar you need is relative to your needs, camping conditions and expectations.
    I find our 230w panel overkill and could do with less. We don't use a lot of power and high altitude gives our panel quite the boost averaging 15a tracking from sun up to sun down. Aside from exercise and AC, the generator hasn't been run this year.
  • Here in IL, at this time of year, 2 moves during the day will pretty much cover it. 3 moves would definitely keep the angles less than 30º all day here. But with the trees at the edges of our property, 2 moves get all the useful sun for me.
    I don't see 100 watts replacing a genset for most campers. But the solar can put a nice finishing charge on a battery or two. Run the genset in the morning to get the batteries quickly up to 80-90%, then let the solar fill them up.
    Although based on my early tests, if we were camping in a sunny region, I think the portable 100 watts would darn near keep up with our usage. It depends if we need the furnace or not. If we keep this camper, I'll put panels on the roof. And maybe still carry the portable 100!
  • I had a Siemans 100 watt panel and used it as a 'portable', chasing the sun around all day, IMO it was a waste of time. I got 7 amps or something out of it (it was a long time ago) but if the angle was off by 45* it was about half of that.
    I think a person needs a min of 200 watts worth of panels to really do any good, I sold it and bought my Honda Gennny.
  • Dakzuki wrote:
    I was toying with the idea of portable panels in my head and came up with an idea. You can buy flag pole holders that fit in hitch receivers like this: LINK Well you take your solar panels, mount them to a piece of tube and plug into the flag pole holder. Want to mount it on the front of the RV? Just get a front receiver.
    Kinda like this ?
  • I was toying with the idea of portable panels in my head and came up with an idea. You can buy flag pole holders that fit in hitch receivers like this: LINK Well you take your solar panels, mount them to a piece of tube and plug into the flag pole holder. Want to mount it on the front of the RV? Just get a front receiver.
  • RJsfishin wrote:
    How do you adjust the panel angle w/ the fixed legs ? Or maybe you have a selection of different lengths ?
    Different lengths. In checking sun tables, I think I can get by with just two, for 45º and 30º or thereabouts. They won't be perfect, but you don't have to be perfect with the angle of incidence from what I can find. I would not be changing the lengths during a given day. Just for different times of year.
    I looked at designs with adjustable legs, but it's not as easy as it seems. Nor stable. With the C-channel frames on my panels, I decided my solution was a good KISS one.
  • How do you adjust the panel angle w/ the fixed legs ? Or maybe you have a selection of different lengths ?
  • I like it! Now you just have to put castors on the bottom of the panels so you can swivel it easily to aim it at the sun whenever you go by it during the day. :)
    BTW your reason for going panel-direct sometimes is to get the batts to a higher voltage than the controller will allow. You can even try for an Equalize if you are out more than a month. Of course you might need to do only part of the bank at once so the 100w will get it done before dark. But at least you have the max flex to do it.
    Once you reach batt 15v and your inverter quits, you can go back to controller to calm things down.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
