dougrainer
Oct 12, 2018Nomad
JaneNLee wrote:
hi and thanks for your reply.It is a duelthermn, is that made from Domentic? I do not have any switch but off and on on the bottom. The 4 buttons on the front are for up and down temo, fan off anf on. I have called a RV mechanic to cone to help. TY again.
WRONG on the 4 buttons. Here is how you change zones. Doug
The front area could be established as
ZONE 1 and the back section ZONE 2. You can select
the desired temperature and fan speeds for each zone
independently, thereby keeping your bedroom cooler
than the front portion of the vehicle. To determine the
number of established zones in the vehicle, simultaneously
depress the FAN and MODE push-buttons.
Zone 1 will be the first Zone to appear in the LCD
readout. Continue to depress and release these buttons
until you see Zone 1 reappear. Zone 2 will then appear.
38,709 PostsLatest Activity: Mar 09, 2025
