2000 Georgie Boy Pursuit Windshield Washer Pump
Sensorone_2
Hi again folks,
I am trying to determine the location of my Windshield Washer Pump.
The washer fluid container is located on the firewall/drivers side.
I see the lines coming out etc. and am wondering if maybe the pump itself is located behind the container. The whole firewall is covered with that insulation foam so it's kind of difficult to determine where the pump might be and I don't want to have to remove the container to look unless it's really necessary. Owners manual doesn't say anything. Thanks for any help.
8 REPLIES 8
Rick_Jay
Sensorone_2,
Thanks for the follow-up. Glad to see that you got your problem resolved. Posting your solution, I'm sure, will help someone else.
Safe travels,
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (27-Angel since 2008), 1 girl (22), 2 boys (23 & 20).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
Sensorone_2
Quick final follow up. The pump did come off the reservoir. It took a little rocking back and forth to work it loose from the plug type gasket that it fits into. I found a new one (Most auto Parts stores will have the same type) but the newer one had pin connectors. So I had to go to a Ford dealer to get the newer connector which came with the splice kit (This was the biggest hassle regarding the whole episode). Anyhow, it was fairly simple to cut, splice, and crimp the new connector on and then wiggle and work the pump back into the rubber plug type gasket (a little spit helped). Works like a charm now. I figured I would post this so it might help anyone else out there with the same problem (Especially the same type RV)
Tinstar
Any tank and 12 volt pump should work fine. I bought a no name one at an auto parts store to replace my tank that split. It came with the mounting bracket and even had hose to attach to the stock stuff. You'd never know it was aftermarket.
:CNever pass up a chance to go somewhere:C
Sensorone_2
Thanks..I'll consider after I run through a couple of more options I have I.E. Some Salvage Yards nearby.
rgatijnet1
Try this as a replacement. I'm sure it would be less expensive than something from Ford and it comes with a new tank and pump. Just remove the old assembly and bolt this one on. Hook up the hoses and electric and you are good to go. Washer pump
Sensorone_2
Well alrighty then. Nothings ever easy is it? The pump looks like it's permanently attached to the reservoir (on the backside). Trying to fins a replacement has been a nightmare. I may have to run down to the Ford dealer since I can't find it online. I tried JC Whitney and used all sorts of search phrases too.
Tinstar
Most are built into the tank. Slide the tank up and you should be able to see it on the bottom.
BTPO1
If you believe that it is behind the tank then you should be able to see a couple of wires going to the tank also. Most washer pumps that I have seen were close or inside the tanks. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
