Red_Racer
Jul 30, 2014Explorer
2008 Southwind 36D battery issue
Hi all,
I realize that battery issues have been covered in just about every way, but this issue is an odd one. Or is it? I think I know what is wrong, but need a second opinion. Read on....
This MH has 2-6 volt golf cart batts in series, that are about a year old. If I measure the voltage across both of them right now, they sit at 12.7 volts but if I use the rocker switch on the batt meter to test the Aux (coach) battery, it measures about 11.5 volts.
If I turn on a set of ceiling lights and start the engine, after about 10 seconds I hear a click, and they get brighter. This tells me that the isolator solenoid is working, and passing alternator voltage to the batteries. At this point if I use the test switch to measure, it reads 14.4V or so, and that is consistent with alternator charge voltage. However if I now measure across the battery terminals I get only 13.2.
If I measure on the Coach Battery cable coming out of the BCC, I get 14.4.
That all said, if I now shut the engine down and put a load on the batts (all lights, frige, one vent fan, Etc.) the battery test switch will now read 12.4, and falls fast. You can watch it fall to 10.5 in less than a minute (same load) and the fridge shows a "Lo Dc" error. But, if I now measure across the battery terminals, the voltage holds at 12.54.
The only thing I see that could be an issue, is the ground connection from the coach batteries to the frame. It looks horrible, and I am convinced this is the problem. I said earlier that I have 14.4V from the opposite end of the positive battery cable where it connects to the BCC. This only leaves the negative cable as suspect. I have not tried to fix that yet because I need to get the coach to my house to do it where all the cool tools are. Too much trouble to haul it all to the storage lot.
Do you all agree? OR, am I missing something here?
thx!
RR
thx!
RR
