2015 Coachman Lepracan coach battery?
jstrong499
On our last camping trip the coach twin 12 volt deep cycle batteries just died. I installed 2 new ones today but no power, lights or reading of the moniter guaves. I cranked the Motor, then the generator cranked, and all work just fine, I turned the ignition off, no problem, cut the generator off and lights all died, no voltage anywhere
Sounds like a breaker or fuse somewhere.
Any ideas???
Jamie in Alabamag
25 REPLIES 25
jstrong499
Yep, its right by the door. I leave it on when camping and turn it off when not. Tomorrow i’ll go out and cleanoff all the brown spray rust repellent the factory must have sprayed on all the metal in the battery box and beside it. Should be plenty of clean connector touching the battery thou. I may trace the red lead under the coach and see where the 12 volt DC coach battery comes into the cab.
Thanks for everyones input
Jamie
4x4van
Is your battery disconnect switch turned on?
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
jstrong499
Also my fuses are in the same breaker panel together. Guess i’ll pull the positive & negative leads and check for resistance tomorrow
jstrong499
Checked all my fuses and breakers, all good. Everything works fine with the generator running, but still no 12 volt operation. Both batteries reading 12 plus volts. There were 2 small 5 amp fuses in the small compartmaent next to the battery box( in the steps) but both 5 amps checked good as well. Its a 2015 coach and this has got me stumped.
bobndot
The ground off my coach batteries was not making contact due to corrosion. Where the ground made contact to the frame.
jstrong499
Ok, that explains that. I’ll be checking fuses and breakers today.
Thanks
Chris_Bryant
When you started the engine, the house was operating off the starting battery, once genset was running, the converter took over.
-- Chris Bryant
jstrong499
Drems strange that when i cranked the coach up that the batteries came online, or seemd to, because the generator spun like they normally would with good batteries?
enblethen
Sounds like battery disconnect is not on. Cycle system to off then back on.
Next would be a fuse adjacent to the coach batteries.
Battery fuse in the 12 volt DC panel
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
K_Charles
That happened at work to a new kid just out of tradeschool. He left the plastic cap on the positive post of the battery when he attached the cable.
Lwiddis
Breakers are the first to check. Then fuses and then clean, strong battery connections.
