Jerry_Amerson
Jun 12, 2017Explorer
Battery switch causing heat up
I put a 60 amp battery switch in line on my ground side where my two 6 volt batteries connect, hot from one side and ground from the other with switch in the middle. When I was at the races my generator got low on oil and shut off and the batteries were switched on and they kicked in until they got low and the converter shut off AC. After I put oil in the generator and it cooled down I started it up and everything was back working and it was charging the batteries. I had just cleaned the posts on the batteries before we left for the races so I wasn't expecting the problem that I got. The two #6 gauge wires connecting the switch got so hot I couldn't hold on to either one, so I don't know if that switch has that much resistance or if it just couldn't handle the current. The other two main lines were not even warm. It could also be that I need to go to a heavier gauge wire. Any good ideas from you all would be appreciated.
Thanks,
Jerry
Thanks,
Jerry
