SJ-Chris
Feb 12, 2022Explorer II
Black waste tank connection question...
Glue the plumbing to the waste tank, or use a removable rubber coupling??
Recently, I had an issue that caused my black waste tank on my 2015 Majestic 28a to be partly disassembled (the piping from the tank itself to the waste hose hookup including the blade valve). My black valve wasn't working correctly also so I decided to replace the black blade valve.
So as I was working with this section of piping I noticed that the pipe joint that connects to the black waste tank itself was not physically connected/glued and simply slid in and out of the black waste tank inlet pipe. Specifically, it wasn't ABS glued together to be joined in a way that I would assume most plumbing to be joined/connected. It is possible there was a rubber union joint with hose clamps on each end to make for a leak-free connection. But I thought it was strange that it wasn't physically glued to be joined in a permanent/secure manner (which kind of surprised me).
My question: Should the sewer line from the black waste tank to the valve and dumping hose connection be all glued together to the black waste tank itself? Or should there be a rubber coupling connecting the waste plumbing to the black waste tank? (perhaps in case something needs to be changed in the future???).
I do think that gluing it all together as one piece makes sense from a leak-free perspective. But before I do that I just wanted to make sure I wasn't missing something. Because once glued to the black waste tank it can't easily be undone and additional repairs in the future would be VERY hard.
Note: The piping from the black waste tank to the valve (which is probably about 1.5-2 feet) consists almost entirely of slight bends and elbow type pieces, so if repairs were needed in the future it would probably require the entire section be rebuilt because there is no exposed straight piping that would allow for cuts and then rejoining with replacement parts. Hope that all makes sense.
-Chris
-Chris
