becker's avatar
becker
Cruise Control - Windshield Wipers
Had a problem a couple weeks ago with my cruise control and windshield wipers not working. All of a sudden (with no input from me) both started working. Everything was ok but then all of a sudden they stopped working. I took it to two different RV shops (and the cruise and wipers started working) but/and neither shop could find anything wrong. I called tech support at Monaco and they could offer no explanation. Last Friday I was at the steering wheel trying to decipher the problem (the cruise/wipers were not working), when I inadvertently moved the adjustable steering wheel from the all the way forward (up) to all the way toward me (down). The cruise/wipers starting working. It surprised me so I moved the steering wheel forward and the cruise/wipers stayed working. I moved the steering wheel to different positions and the cruise/wipers continued to work. I turned the engine off. Then I started the engine again and the cruise/wipers did not work. I then moved the steering all the way towards me (down) and the cruise/wipers started working again. I repeated the procedure several times and the same thing happened. The cruise/wipers did not work until I pulled the steering wheel all the way towards me (down), then the cruise/wipers started working again and continued to work until I turned the engine off. I'm baffled.
My question is: Have any one of you guys out there ever experienced a situation like this? I would certainly appreciate your input.
