supercub
Jun 14, 2015Explorer
DC Electrical Problem. HELP !!
04 Fleetwood Revolution with 4 - 6 volt house batteries. Batteries are Trojans less the a year old.
I'm currently plugged into shore power, 50 amp service.
Yesterday my lights were dim, so investigated, the positive lead from the battery to a fuse link was so hot you I couldn't touch it. One of the terminal ends was loose. Went into Klamath Falls about 25 miles away and was able to get a new cable with new ends made.
Installed the new cable and everything appeared to be ok. Checked the cable again last night and was cool to the touch. When I went to bed last night I noticed the Norcold Frig window going thru various indications, didn't pay much attention to it. Got up this morning and lights were very dim. Looked at Norcold and it's flashing Lo dc. Checked battery cable and it's cool.......batteries are at around 10.5 volts. The cable side from the batteries of the fuse link is 10.5 volts. and the other side is of the fuse is 13.75 volts.
All AC in the couch is working fine.
My Xantrex indicator shows the following.
The 3 little battery indicators shows full
AC in light is on
DC volts is 13.5
Incoming AC Breaker Amps 30 (I'm hooked up to 50 amps)
Should I start the generator and see if the batteries charge up.
Any help is greatly appreciated.
Thanks
Brian
AC in light is on
DC volts is 13.5
Thanks
Brian
