jdavidsmi's avatar
jdavidsmi
drivers side mirror loose
We have a 2004 Fleetwood Terra 31H, with 54000 miles v-10. On the way home from Florida last month, I notice the drivers side mirror was vibrating, but the passengers side was not. When we stopped for fuel I checked it out, I was able to pull 3 of the 4 mounting screws out without turning them. I had some hollow wall anchors with me and was able to get 3 in and to tighten. and come on home. I have not had much time to investigate but what I have found has me worried.
I believe there was a large block of wood mounted between the walls when the coach was built, and over the years it has rotted away. This area is between the front cap and the drivers window. when I was looking at it yesterday I saw a small bubble under the vinyl wall covering on the inside. so I'm guessing water got in.
Without damaging the exterior fiberglass what would be the best way to repair?
A couple of things come to mind. inject epoxy that will fill the space and harden, open up the interior wall and replace the wood. Are there other ways that would make the repairs?
Thanks in advance
David
