CloudDriver's avatar
CloudDriver
E450 Rear Brake Pad Replacement - long post w/pics
I recently finished replacing the worn rear disk brake pads on our 2003 E450 chassis and thought that other DIY folks would be interested in the problems I encountered and the tricks I learned.
I have been doing brake jobs on my cars since the 60's and the change from drum brakes to disk brakes has made replacing the friction material, aka brake pads, so much easier than replacing brake shoes on the old drum style brakes. I figured that the brakes on the E450 were just larger, heavier versions of what I had seen on cars. While this is true, there are differences that made the job more difficult.
The first problem occurred after I had jacked up one side of the rear axle and removed the lug nuts. I discovered that the wheels wouldn't come off. The inside diameter of the wheel rim is a snug fit over the axle hub and rust that had formed in the tiny gap prevented the rim from moving. Application of Liquid Wrench, prying, hammering, etc. did nothing to break the rusty bond. After a half hour of struggle, I recalled reading about a trick to break rusted rims loose. I put the lug nuts back on finger tight, dropped the MH off the jack and drove a short way down the driveway. A sharp application of the brakes resulted in the wonderful clunk sound of the rim breaking loose from the axle hub. This trick works because the holes in the wheel rims are over sized for the lug bolts, so loose lug nuts combined with sharp braking causes the rims to move slightly against the hub.
Picture of oversize lug bolt holes and tight fit of rim on hub
After jacking the wheels back off the ground, I was able to wiggle the outer rim and after about 10 minutes of effort finally got it off.
Picture showing rust on hub before removing inner dual. The inner dual also required lots of wiggling to get it off the hub.
I had chocked both front tires as well as the duals on the other side before jacking, but I don't trust jacks. So I used the wood ramps that level the MH when it's parked in the driveway to catch the axle hub if the jack should fail or the MH fall off the jack.
The next problem was getting the caliper off. All of the cars I had worked on had caliper bolts to hold the caliper in place. The E450 rear brakes have caliper pins, which must be driven out of slots in order to remove the caliper.
Outer end of upper caliper pin circled in red.
There are raised bumps on the ends of the caliper pins to prevent the pins from working themselves out when going down the road. The service info I had downloaded from Ford said that there is a special tool to squeeze the end of the pin so that it can be driven out. The local Ford dealer didn't carry special tools, so I came up with another way to squeeze the end of the pin. In the picture below, the two flat blade screw drivers tapped in with the hammer act as wedges to squeeze the end of the pin, allowing the raised bumps to clear the edge of the slot.
A 3/8" ratchet extension was the perfect size to drive the pin out with some hammer taps.
Close view of end of pin with raised bump circled. The bump is shaped with a slope on the outer end so the pin can be driven into the groove easily when assembling the caliper. The sharp edge on the inside prevents the pin from sliding out. The pins are constructed as `a sandwich consisting of shallow V's of stainless steel with rubber bonded between.
The outer brake pad is attached to the caliper. This made it necessary to do some hammering and prying to get the caliper with pad off past the slightly thicker outer rim of the brake disk.
On the driver's side, the brake hose was long enough and had enough flex to allow the caliper to be removed from the disk. On the passenger side the hose was shorter and it was necessary to remove a support bracket where the hose was attached to the metal brake line.
Once the caliper was free, it was hung with wire to keep strain off the brake hose.
After removing the outer brake pad, a C clamp and a block of scrap wood pressed the two caliper pistons into the caliper.
A comparison of the old and new brake pads. The old pads had almost 81,000 miles of use and still had about 1/4" of friction material remaining. Might have been able to go another 20,000 miles.
Before installing the new brake pads, I cleaned the caliper pins and lightly sanded the caliper pin grooves and caliper surfaces that come in contact with the pads to remove rust. These surfaces were then given a thin coating of caliper grease, with care taken to keep the grease off the pad and disk friction surfaces.
Picture of the reassembled caliper.
Before installing the wheels onto the axle, I lightly sanded the rim/hub mating surface and applied a thin coat of caliper grease, in the hope that the wheels won't be rusted to the hubs the next time.
Inner wheel on greased axle hub.
Since I hadn't disconnected any brake lines in doing the job, there was no need to bleed the brakes. A few pumps of the brake pedal extended the caliper pistons against the new brake pads. A syringe removed the excess brake fluid that had been sent to the master cylinder earlier when the caliper pistons were compressed.
After finishing the other side I took the MH for a short drive. Brakes work fine, good for another 80,000 miles.
