Fleetwood_Coupl's avatar
Dec 14, 2018
Engine and coach Battery Disconnect Switches
ok so I have 2 switches on my pannel for Batt disconnect and they have a red light indicating they are on, switches are spring loaded to the center position, when i hold them to off nothing happens light stays on, batt voltage indicator shows full. is there a certain process to follow ?my book doesnt address it only mentions the switch for storage.
  • ArchHoagland wrote:
    Here ya go Chief:
    Battery disconnect
    Works every time....
    From an old ETN2
    thanks I was trying to use what was already installed. Its a thought but i would prob just pull the negative terminal as little as i need to do this.
  • I had a 1989 Class A that had the panel with the toggle switches.
    The switches controlled a "Latch Relay" (power one way closes relay, power other way opens, that's why rocker switch) that looked just like an automotive solenoid
    but it is not and costs close to $100.
    There was a 5 amp fuse near the relays and someone put in a 20 amp fuse, the switch stuck on and burned up the relay.
    Find the relays, look for a fuse, and make sure the switches aren't sticky!
  • wa8yxm's avatar
    wa8yxm
    Ok do not use your eyes.. Use your ears
    When you press a switch (On or off) do you hear a CLUNK? You may wish to have someone else listen and walk around the RV as you press and release
    The circuit
    Switches are DPDT Center off with the leads crossed so they are reversing switches (I will try to draw
    +_________________
    -______X__________Solenoid
    The switch either connects "Straight through" or crossed over to turn on/off
    Solenoid is a magnetic locking device
    It will "Clunk" when it switches
    Why not use your eyes
    The LIGHT means "12 volts is present" if you are plugged into shore power or the generator or main engine are running 12 volts WILL BE PRESENT. it does not mean "Batteries connected" unless you have no other source of power.
    Absent a decent load it can take a while for that light to go out due to filtering in the converter To hasten it turn on ceiling light or fans
  • I have double switches also but when I toggle to off, the Red light goes off indicating the relay(solenoid) has disengaged power.
  • RLS7201 wrote:
    Try unplugging shore power and see if you can disconnect your batteries.
    Richard
    it was
  • Try unplugging shore power and see if you can disconnect your batteries.
    Richard
  • I have an 05 38N. I never use my switches but one is for the engine batteries and the other is for the house batteries.
    They toggle the relay so if you rock it once, all your 12 V lights should not work.
    If I remember the voltage still shows either way.
    Intelitec has PDFs online for all their stuff.
