Paul_Guenther's avatar
May 18, 2023
Headlight only works on high beam
My passenger side headlight only works on high beam on my 2002 Tiffin Zephyr. Driver's side works fine. Have replaced the bulb. Any suggestions will be appreciated!
  • Assuming the new bulb is OK then it's most likely a wiring connection between the two bulbs,
  • wa8yxm's avatar
    wa8yxm
    I oncce had a connector with a bent pin.. It did not go into the socket properly. Straightened it and all good.
