location of battery on a newmar dutchstar
BigAWB
I have a 2000 Newmar Dutch Star diesel pusher with a diesel generator. I can't start the generator because the code says low battery. Can anyone help by telling me where the battery is located. As far a the coach its self, it starts fine. I usually can figure these things out for my self, but this one has me stumped. Thanks for any and all help.
3 REPLIES 3
dougrainer
2000 Newmar Diesel Pusher, the CHASSIS battery starts the Genset. IF the Diesel engine starts, but the Genset does NOT, then either the 12 volt battery cable system from the rear to the front has loose or corroded connections, or the Genset has a problem regardless of 12 volt supply. If your Chassis engine does NOT start, then that battery is your problem. The Chassis batteries are located in the Passenger side rear most compartment. The Coach batteries are also located in the same compartment. They are on a slide out tray. Doug
Tom_Barb
Newmar will answer the question with a call to there companies tech help number.
The gen-set normally uses the chassis battery to start the gen-set. with a battery boost from the coach batteries.
http://www.newmarcorp.com/get-answers/
Have the last 5 of your VIN ready to give to them.
They still service every coach they've built.
jorbill2or
The generator uses the house batteries in some cases. It defiantly doesn't have its "own battery" chassis or house are the choices. Are your house battery's dead or low? Perhaps a loose connection ?
Bill
