goufgators's avatar
goufgators
New tire psi question...
I try to run 85 tire psi on my coach but, as I drive, pressure increases to, often, 100 psi. That's not the maximum rated psi for the tires so that doesn't bother me but what does concern me is that at 100 psi the ride is harsher and control (steering) becomes a problem due to a tendency to wander. The coach drives much better at the lower 85 psi. My question is: since 85 is the correct psi...can I (should I) inflate to...say 75 psi (cold) knowing that a few miles down the road the pressure will be at the required 85 or 90 psi? Thanks for any input! / Larry
