gsf35099
Mar 22, 2015Explorer
Power Gear Leveling Communication issue
I've been searching & reading all I can find & looking for some advice.
My touch pad (obsolete #500629) is flashing & manual says its a communication issue. Either bad connection or failed component(s). Troubleshooting guide says start with harness connections to make sure all good & if still problem start with replacing harness, then touch pad, then control panel.
Everything was working fine although I was having to unplug my touch pad because the jacks down light would keep flashing & alarm when driving. Think my fluid level sensor went out a while back because the fluid has been fine (checked with all jacks up).
I've always made sure the power was off before unplugging or plugging the touch pad back in, but before this last trip the communication issue popped up.
I have checked all the harness & really have a hard time thinking that is the cause since it was working great, I raised the jacks, went & got propane & when I got home, killed power, plugged touch pad in & problem started. At least the jacks where up so it didn't ruin our trip to Bike Week!! :-)
I'm having one heck of a time finding a touch pad with my # & there is a replacement new one of 140-1226 but I can't determine if the harness (existing) will just plugg in. I think the plug on the new touch pad is a different connector.
Apologies for the lengthy message, but looking for folks that have upgraded & can give me some advice.
Thanks
Thanks
