Power Gear Leveling System won't reset
gb76087
Power Gear electric levellers, Control Box 140-1224, Rev 0G.
My mistake, started engine while lowering levelers. Unit went into error mode. MAN, AUTO, and all four jack lights began blinking. I manually raised all four jacks, but the lights still blink when engine is started. When I turn the touchpad on, the jacks down light comes on along with the others. When I put the coach in gear, I get the dreaded beeps.
I later read where I need to extend all four jacks 4 to 6 inches, then try and reset and retract.
Is there a way to reset without manually lowering all four jacks?
2007 Fleeteood TERRA LX 34N
F53, 362hp V10
2 REPLIES 2
gb76087
Problem resolved!
You must manually lower each jack 4 to 6 inches, reset the panel(on mine, press all four directional keys at the same time and wait for beep) and then the jacks can be raised.
F53, 362hp V10
bdpreece
You might try disconnecting the batteries for about 10 minutes then reconnect and test.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
