gb76087
May 14, 2015Explorer
Power Gear Levellers in Error Mode, Can't Reset
Power Gear electric levellers, Control Box 140-1224, Rev 0G.
Put system in "AUTO" mode and system worked as it should. I then put it into "MAN" and began to fine tune level. System went into "Error Mode" with AUTO/MAN lights flashing. FRONT/LEFT lights were also flashing, indicating problem with front left Jack. I then turned unit off and back on. Held OFF/ON button for over 3 seconds, unit did not reset as documented. I then held FRONT/LEFT buttons, pressed MAN to lower Jack, I got 3 beeps. Tried again, but pressed AUTO to raise Jack, Jack moved a little, then the dreaded 3 beeps. Now unit is in ERROR MODE and wont reset. Any ideas?
