โJul-27-2016 03:07 PM
โJul-29-2016 07:35 AM
J-Rooster wrote:hipower wrote:J-Cat, glad to hear that your really learning about your CAT Motor and what it takes to get it running good. Highpower, those were the good old days! Keeping those diesel motors right on 2150 RPM's and if you shifted into neutral with the Jake Brake on it would kill the motor! My boss perfered us to take our foot off the throttle when the pyro got to 1000.
Those of us who have some trucking experience in our backgrounds drove when pyrometers were prevalent. Measuring your exhaust temperature was almost a neccesity to keep from cracking a piston or exhaust manifold in the early days of turbocharging OTR diesels.
I don't recall the exact temps suggested but they were different depending on the probe placement, pre or post turbo. Somewhere in the dark recesses of my mind I think it was 1200 degrees pre turbo and 800 degrees post turbo, but I can't swear that is correct anymore.
The key here is that if your EGT was too high you downshifted a gear and backed off on the throttle to keep the EGT in an acceptable range. Using our coolant temps to guide us is just a less accurate way of doing the same thing.
Bottom line, if you experience temps that make you uncomfortable while climbing a grade downshift and reduce throttle input to bring the temps back down.
โJul-29-2016 07:03 AM
โJul-29-2016 04:43 AM
โJul-28-2016 05:13 PM
โJul-28-2016 05:01 PM
โJul-28-2016 03:36 PM
โJul-28-2016 03:19 PM
โJul-28-2016 02:25 PM
tinkerer wrote:
That is exactly the same thing I do when climbing that same grade. I like to keep the rpms at 2000 or above. This also a C7 Cat.
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
โJul-28-2016 09:04 AM
โJul-28-2016 08:30 AM
ricelake922 wrote:
This article is very interesting but if you have automatic how do you downshift to help the engine overheating issue?
โJul-28-2016 08:13 AM
Click here to see where I am
โJul-27-2016 10:27 PM
DrewE wrote:wolfe10 wrote:
Bottom line: It takes XX HP to climb a grade. If you generate that HP at 2000 RPM instead of 1600 RPM, the FAN and WATER PUMP are turning 400 TIMES A MINUTE FASTER.
It takes xx hp to go up a hill at a certain speed. At a lower (vehicle) speed, it of course requires less power. If by downshifting the vehicle speed also slows down, you not only have possibly more water and air flow, but less heat generated by the engine as well--a double improvement.
โJul-27-2016 09:19 PM
โJul-27-2016 08:43 PM
