- st687ExplorerGo to Ace Hardware and ask for a Zoom Spout turbine oiler.
- dstock50ExplorerNah, Never/Never use 3 in 1 veggie oil on any motor, most recommend 20 weight.
- ValkyriebushExplorer IIThanks all.
- howdy35Explorer IIHad the same problem with mine. Oiled, WD-40 and others. Finally replaced mine. U-tube will show you how and with some tools and general knowledge, you can do it yourself. Take it out, order a new one and put that one back in. Good luck.
- John_WayneExplorer IITo stop mine I had a little side to side movement on the motor shaft and the squirrel fan on one side was hitting the housing. I just loosened one of the squirrel cage fans and pushed both fans towards each other ( on mine there was a fan on each end of the motor) and retighten the loosened fan. Mine was an attwood furnace.
- RoyBExplorer IIWD40 spray will blow out debris perhaps and quieten things down for a bit but you really need to get some machine oil in the bushings...
Roy Ken - wolfe10ExplorerThe fan motors have BUSHINGS, not bearings. Though access can be a little tricky, you can put a couple of drops of non-detergent light viscosity oil (like sewing machine oil) on each end of the shaft and let it wick in.
Permanent solution is to replace the motor.
About Motorhome Group
38,707 PostsLatest Activity: Feb 18, 2025
