Warning light comes on while driving - Level jacks down!
donnyB7
While driving down the highway, my warning light came on, along with a ringing bell noise that my leveling jacks are down. Scared the tar out of me, so I stopped to look. The jacks were all up and the warning stopped. About 10 minutes down the road, the warning started and stopped a few more times. Can I assume it is a bad sensor, or is there something else I should check?
29 REPLIES 29
tropical36
donnyB7 wrote:
https://photos.app.goo.gl/OCqQv4qY6YQq0RNy2
Try this link.
My chassis is the Ford. It's the V10 engine.
Some info on an ...
09
Some images and a trouble shooting guide and still not sure if you have a Lippert or a Kwikee...Pics
Possible your filler cap, also houses the float, with two wires coming out, but most likely the cap is alone and shown to the upper left in one image.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
donnyB7
Try this link.
MrWizard
Moderator
Moderator
What chassis? Work horse with Chevy engine
Or
Ford chassis and engine
Either way , the reservoir is there in the front at the pump
You need to retract the slides and Jack's
Crawl under Neath, remove the fill plug and add some fluid
No you can't do it properly with the slides out, you will need to much fluid to fill it, and it will blow out all over the place when you retract everything
You could measure out, about 4 ounces of ATF and put that in
And go for a test drive, and see if it alarms
But you have to be real careful to add only a couple of ounces per try or to will overfill it
I can explain it to you.
1997 F53 Bounder 36s
tropical36
donnyB7 wrote:
Here is a drawing that shows a schematic of my leveill ling system. I am still not sure where I check the fluid level.
Image didn't come through, but It should be a long black cylinder if Kwikee brand and maybe 6" dia. x 18"L, would be a good guess, with the filler cap at the top.
donnyB7
tropical36
Add a little fluid and see what happens. Most likely the cause.
dougrainer
donnyB7 wrote:
I finally had some time to check the fluid level. I had to extend the slide out behind the drivers seat to get access to the HWH system. There were four horizontal cylinders that looked something like oil filters. They were attached to a metal block that had an oil plug above each of the four cylinders. Do I have to check each one or is there another place where the fluid level is checked?
NO NO NO!!!! Do NOT remove those plugs. The reservoir is the large BLACK CAN mounted to that solenoid assbly. 1 easy twist off filler plug mounted in the center. Doug
MrWizard
Moderator
Moderator
unless you have (2) independent hydraulic systems, one for the jacks, one for the slides, the slides will need to be retracted
IF your slides are 12vdc motor gear driven, that is NOT Hydraulic
then check the pump reservoir for a large plastic cap/nut
level has too be checked in the hydraulic reservoir
with jacks retracted
putting fluid in the system with slides or jacks out , will result in over flow (possible damage) when retracting
you are in the wrong place
the reservoir on this Safari is in the engine service bay, curb side rear of RV
please post a picture of the pump ?
IDK where yours is at, it should be Labeled
Power gear levelers, have the reservoir at the pump
donnyB7
dougrainer
psquire wrote:
This happened all the time in my former coach, a 2004 Newmar Kountrystar. It even occurred on my first trip in the coach which scared me to death.
It mostly happened on hot days. And of course no technician could ever figure out what the problem was.
Eventually it turned out that one of the hydraulic lines to the jacks was run close to a hot part under the coach. When the hydraulic fluid heated up it caused just enough expansion to cause one of the jack cylinders to descend about 1/4 inch, just enough to trip the alarm. Apparently it was a design flaw.
No design flaw. READ my post on the 300 series HWH jacks. The 600 series has a different magnetic switch and control system so you don't experience this type problem. ALL you had to do was push STORE each time you started the chassis engine to drive. This is stated in the HWH 300 series operators manual. Doug
psquire
Mile_High
garyemunson wrote:
If it has the Lippert hydraulic system the jacks are held in the retracted position by hydraulic pressure. A pressure sensor detects low pressure on the retract side and alarms. Bad sensor or a leak can be the cause.
Cool, I didn't know that. I thought they maybe used limit switches. Another spring project 🙂
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
garyemunson
wa8yxm
mccsix wrote:
Some models it means low fluid level.
At least 2 companies I know of that is what it means.
One is POWER GEAR.. Not sure of the other but AVA seems to be what I recall
In the heat of summer the fluid expands faster than the tank and thus it overflows
THen when it cools off. the fluid "Contracts" faster than the tank and LOW FLUID happens so the Jacks Down alarm,,, is very alarming.
Could be worse.. This AM while I was taking down to go for an oil change I kept hearing beep beep beep.... beep beep beep.
I have a few alarms that do that in my RV, every last one of 'em means "YOU WILL BE DEAD if you don't do something fast"... I called Security.
