robertdmunn
May 25, 2019Explorer
Inverter/solar install questions
I am installing an inverter and solar panel setup in my Volante 380MD 5th wheel. I have a Magnum 2812 inverter, 2x 100AH lithium batteries, getting 400AH more of batteries soon.
What I am thinking of doing is making the current primary electrical panel the subpanel and installing a 2nd panel as the main panel with shore power and AC, converter and other services I do not want to run off the inverter in the new panel. I also plan to move the shore power plug from the rear of the RV to the front, closer to the inverter for a shorter power run.
Looking for suggestions or cautions on my plan. I have most of the gear but might need more cable to move circuits to the new panel.
Thanks in advance ...
