E.crowder wrote:
I have a norcold 2118, What should the temperature be at the condenser fins for refrigerator to operate properly. With button thermostat bypassed I am running at 130 deg F.
I have NEVER had to factor in the Condensor temp.
1. In 99% of installs you cannot get access to the Condensor to take a measurement
2. The button Tstat just activates the rear cooling fans.
3. The purpose of the condenser is to REMOVE the heat. The air flows up from bottom and thru the Condensor fins and removes the heat and flows out the roof. Now, correct install is critical. You must make sure ALL the upward flow of air goes THRU the fins and cannot go between the back side of the fins and the sidewall of the RV. Doug
